350 vortec swap
For the oil cooler lines you can unbolt that housing and bolt in one from a V8 without oil cooler.. the block mounts might be long so get some off a monte, caprice, camaro V8.. frame mounts bolt in 1st 3 holes only(2 at top 1 at bottom) each side thats close to the radiator... that will get the engine in the car...
Just finished putting one in my Monte, using the Tahoe serp setup, u will need a different water neck, because of where the ac compressosr sits, electric fuel pump, he I dizzy,but now I need a new water pump, my question is can I use the one off of 91 350 block
well i have no idea who to believe on this website cause everyone says you cant and now you say you can what the **** is the point of asking i guess i should just try for myself
