A little off topic but an option for mounting instead running bolts into the frame is you use a square u-bolt and open the hole on one end and slotting the other and you basically end up with a pair of studs hanging down, works great on thinner frames that easily strip out.
The "legs" would need to be shorter than pictured but you get the idea.
