I'd like to know what bushings you guys used with the 36mm hollow front sway bar...and if you have a part # available.
I tried using the F-body bushings and brackets, but of course I had to elongate the F-body brackets to line up with the mounting holes. It sorta fits, but I'm not 100% satisfied with them. The F-body bushings do not fit in the brackets for the 32mm bushings.
The outside diameter would have to be the same, or close to the 32mm bushings.
