36mm sway bar bushings
The brackets on a g body are all the same. The difference in diameters of the bars were accommodated by the bushing
Thanks Steve,
That should help narrow down the search. 🙂
So you're saying that the brackets are all the same, just the i.d. of the bushings are different.
Jack, get the greaseable bushings from Top Down Solutions in California. I installed the F body 36mm hollow front sway bar on my Monte last year, using a pair of G body brackets that were drilled and tapped for a grease fitting, along with the Top Down bushings, and it worked great. Hope this helps.
Jeff,
A few other guys have suggested using the TDS greaseable bushings. But I've already ordered the MOOG parts. I suppose I could drill the bracket and bushing and thread in a few zerk fittings.
Thank you guys! I appreciate all your input and suggestions. 😀
