BUILD THREAD 36x48x14 Shop Build Update 2/20/2024, Tire Machine is Finished!
liquidh8
I've stated in my Wagon Build thread that I am building a new post frame (pole barn) shop in the back of my land. I have been working out of my 32x25x10 attached garage, and need to get out of it! Stage one of Mehl's Mountain Garage-mahal is a 36x48x14 heated section, with 2 10x10 doors and a man door. I have received the permits, have the funding, and already prepped the site for the building. I am strapped for time, and help, I am not erecting the building, I have a company doing it. Besides, after factoring in a kit, equipment rentals and such, it was only a few grand more to pay a crew to do it. I will however be doing the data, electrical, HVAC, and possibly the metal/drywall interior. I am leaning towards spray foam for insulation, though I am still pricing out options. The concrete I have yet to secure a company, it is to much for me to do alone. Though, I may prep it and just have someone pour and finish it to save cash.
The materials showed up this week, and the crew is scheduled to be here next week to begin, weather permitting as it has begun to rain.
Reactions: 10 users
liquidh8
Some pics.
These trees needed to come down and the topsoil needed to be scraped off. It was 6-10 inches thick in spots, this land has been untouched before I bought and built on it. After the topsoil was removed, 10 triaxles of compactable fill were delivered kinda close (1000 ft give or take a 100ft away), and transported via skid steer to the location, an absolute mission! It tore the ground up pretty good also.
E42 Mini-X for the win, just pushing over pines and sadly a few birch.
I didn't get many pics of the leveled (within 2 inches) and graded site, but I will later.
The path through the aptly named "Tent City", a mud fest for now!
Building materials, managed to get them close to the site.
The trusses are a different story. They are 48' (or 50' since there are 1' overhangs) and the came on a semi. No WAY I was getting that truck back there. So he had to drop em in my front yard, the contractors will move them.
More pics as the work progresses!
  • Love
Reactions: 14 users
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Wow I'm jealous! Looks like you'll end up with quite a shop.
If I can recommend two things. Do the spray foam. Second best would be 2" foam board cut and placed between joists, poles etc. Other would be to install hydronic pex in your slab, even if you think you're going to use forced hot air. But only if you plan to keep it heated all winter. Heat up time is poor for a heated slab. Lot of mass to heat up. You can't put the pex in after the concrete is poured of course. Having worked in a shop that had heated floors, it's flat out amazing. Open a door, pull a vehicle in. Temp drops of course. 5 seconds later it's back up to temp. That doesn't happen with forced air.
Reactions: 10 users
Supercharged111
4,932
7,712
Colorado Springs, CO
So with spray foam, is there a need for a vapor barrier? All the "how to insulate your pole barn" and "how to add a lean to to your pole barn" are 100% done by hacks who don't use any drip edge (or cut through siding to anchor directly to studs) or vapor barrier. It's pretty bad when someone who's not a builder can spot that from a mile away.
WyoGN
Sep 24, 2022
68
101
33
at enough depth, it can be....9 in. in the ceiling can keep you from venting the roof. A big plus in fire prone areas. no sparks getting in the attic
Tomeal
919
1,632
Clyde,pa
I would tell you to consider at least putting the pex in the slab. If you change your mind later on, it's at least already there.
I've been in some garages with heated floors, you could take a nap on the floor.
liquidh8
You're making me jelly. I'm a couple years out but crunching numbers and scouring code for my own house then pole barn build right now. Sub'd.
Thank you, this has been a long time coming! My old house wouldn't allow me to do this, and with deployments, and military duties, I am just now able to do this! I am very excited!
Thank you! I have a few quotes for spray foam, I am also going to hit the energy/insulation company who did my house. One way or the other, this shop will be air tight, since air leaks are the king off all heat transfer and loss. My cousin's husband (neighbor), is a master plumber who I work for on my days off. We are looking into to doing this exact thing. As you stated, it's easy to do now, though the insulation is not that cheap.
I agree, and I am leaning heavily towards this!
liquidh8
According to the spray foam guys, no need for one where the foam is getting sprayed, since the foam essentially is the vapor barrier when cured.
