he contacted them about their gear feel issue
Care to elaborate??
Mark said, there is something off with there recent pumps. Multiple pumps feel notchy, they should be nice and smooth.Care to elaborate??
Weight should only need to be removed for externally balancing. If it is internally balanced, all of that offset outside the engine STILL needs to get INTO the counterweights. So granted your pistons and rods are a little lighter, it may still not be enough to meet the external weights.So the saga continues, the machine shop called and gave me the number of the balancing shop. He said, they could not internally balance my crankshaft. I called the guy, he said they didn't have the capability to add Mallory weights, WYF? Really, this is the shop you sent my crank to for internal balancing! I told him, weigh my pistons and rods, they are about 600 grams each. This 330 crank was supposedly balanced with heavy 18cc dish Speedpro forged pistons on heavy stock rods. I told him to please check first, if anything, weight should need removed from the counter weights. He was going to check, I left Wayne my number🤔.
So all 8 pistons and rods are less than 1 lbs lighter total? How much is the counterweight outboard of the engine?Actually the pistons and tods are 400+ grams lighter. I will talk to them at the end of the week and see what they found.
