3800 Super&Turbo Charged
Zach, you should be able to get a BCM out of a junkyard if you can find a car that has both. The computer just needs the fuel enable signal. Our boy, TURNA, threatened to tell me how to do it without the BCM, but dissed me like a 2 bit, transvestite hooker.
*fun fact: tr4nny gets automatically corrected to transmission by the site
Reactions: Turbo Zach
Zach, you should be able to get a BCM out of a junkyard if you can find a car that has both. The computer just needs the fuel enable signal. Our boy, TURNA, threatened to tell me how to do it without the BCM, but dissed me like a 2 bit, transmission hooker.
I have the BCM, just not the keys.
There are only a few possible resistors. You can buy a while kit and do process of elimination. So your odds are like 16% the first try but they go up pretty fast from there. Probability is that you will get it on the 4th try. That's if you have to brute force it and don't just get the VATS blown away by an aftermarket tune. If you have a friend with a good scanner, maybe a Solus, they can just read it but that somehow seems like cheating
If I have the coin when I get to this? I would like to use a Holley ECU. That would be all around better deal with tuning a turbo I think?
Reactions: fleming442
I think a super charger in a pig would make a good daily driver. I am curious how the blower and turbo performs? I know by doing that you can run a much larger turbo, but with the modern turbos we have now I think it is kind of a lot of work for not much return. I am sure Bison could come up with a single turbo that would perform better.
The stock eaton s/c would be a bottle neck. A properly sized ball bearing billet wheel turbo would outperform the setup in the original post in all aspects.
I agree and was trying to say that. I think a blower engine in a G Body daily driver would be a good option. ( like the Pig)
