So this is obviously not right. Here's the info:
Block: 1996 up vortec 350 with iron vortec heads.
Serpentine accessories: both aluminum brackets, ac compressor, alternator, crank pulley, and water pump from a 3rd gen Camaro
Water pump pulley: supposedly from the same Camaro donor car.
Does anyone know of a part number for a water pump pulley that will alight with the rest of my set up? Everything else lines up. I've already shimmed the water pump pulley out to the end of the snout of the water pump (not pictured, but it's still off by an 8th inch or so and the belt is fraying)
I'm looking at these two from summit: https://www.summitracing.com/parts/ADO-19368329
https://www.summitracing.com/parts/ado-19367392?rrec=true
This is what the brackets and pump look like bolted up.
