Is it "nice running" without the comma?a nice, running cutlass supreme with a 350 diesel in it
Olds diesel market is still pretty hot in Europe & Scanandivia i got engs on backorder for some guys i do business with.Deals are out there for nearly anything Olds but a 455. They are $500 minimum, usually knocking or 8 to 1 J head motors. Another reason why I don't buy them or plan on building one. I picked up a great running 76 350 for $120, he wanted $150. It had 140 to 142 psi after installing the compression robbing Performer cam and 20+ psi hot idle in gear, 25+ psi in park and 50 cruising with 5W30 oil. It still had shim head gaskets and the nylon looked perfect on the timing set. He had a knocking 455 that he would sell but it was much more valuable. I said no thanks and took the great running 350. The Olds Diesel has a tiny market, so yeah almost no demand.
Glad to hear, they killed the passenger car diesel market for 30+ years in North America. If only they built the 4.3 V6 first, you know the right way, water fuel separators, extra head bolts and gee golly, long enough main bolts! Imagine those hooked up to the T50 in the new downsized 78 Cutlass, reliably getting 40 mpg. Then Turboed by the early mid 80's, performance and mileage way before the VW TDI. Typical GM, finally get something right, then cancel it shortly afterwards.Olds diesel market is still pretty hot in Europe & Scanandivia i got engs on backorder for some guys i do business with.
There is the v8 4.3l diesel that came out in '79. And ended in '79.I've seen the 4.3 v6 mentioned a couple of times through out this thread, are all 4.3's diesel, or are there both gas versions and diesel versions? I just picked up a parts car elky that is supposed to be a 4.3 so I was just wondering.
And chevy did put the diesel v6 4.3l in the g body cars.Olds had a diesel 4.3L V6. Chevy had a gas 4.3L V6 with TBI, sorta 3/4 of a SBC 350 block, no relation to any Olds motor. Your Elky no doubt has the Chevy.
