406 vs 400 sbc
Discussion in 'How-To's / Knowledge Base' started by Link, Jun 4, 2018.
  1. Link
    Link Not-quite-so-new-guy
    Feb 13, 2018
    23
    I am thinking of doing a 406 build and I was wondering if it would be better to just keep it a 400 for a budget drag build
  2. lilbowtie
    lilbowtie Royal Smart Person
    Jan 7, 2006
    1,957
    875
    Canton Mi
    If you have a measured good std bore why would you ?
  3. melloelky
    melloelky G-Body Guru
    Oct 22, 2017
    501
    336
    mass
    lilbowtie's right, if you don't have to why bother.depending on what your plans are come into play also.
  4. fleming442
    fleming442 Comic Book Super Hero
    Dec 26, 2013
    2,651
    959
    6 cubic inches is irrelevant unless it's on the end of your....
    Nevermind
    • Funny Funny x 2
  5. bracketchev1221
    bracketchev1221 Greasemonkey
    Jan 18, 2018
    129
    75
    I would use whatever could get a clean hone with a torque plate and keep piston to wall acceptable.
  6. 88ss408
    88ss408 Master Mechanic
    Feb 25, 2007
    267
    13
    baie st anne n.b
    A 406 is a .030 overbore. If your standard bore is good run with it. But if you have to bore and can get away with .010 or .020 do that.
  7. 81msw79
    81msw79 Master Mechanic
    May 5, 2013
    371
    61
    roselle park , nj
    I agree with all the statements above. A factory 400 block is notorious for issues once you start punching them out. The walls are thin to begin with compared to other sbc cores. If you need to clean up walls keep it light like 88ss408 suggested. I got lucky with my short block it is standard bore and clean. I am just going to hone it and rebearing bottom end with some new pistons.
    • Agree Agree x 2
  8. Texas82GP
    Texas82GP Comic Book Super Hero
    Silver
    Apr 3, 2015
    4,295
    3,301
    Spring, Texas
    Totally agree. When I bought my car it had a 400 in it. It was pretty tired. I pulled the heads to take a look. It had already been bored 0.030" and had pronounced ridges at the top of the cylinders. The consensus was it needed to be sonically checked to see if it could take a 0.040" overbore. I sold it and moved on.
    • Like Like x 1
  9. bracketchev1221
    Jan 18, 2018
    129
    75
    Just don't lock yourself into weird engine sizes. Check piston availability for what you want to do in the size you are looking to go to. No point in going to .010 or .020 if race pistons will cost twice as much as shelf .030 pistons. SRP and JE have a large selection of bore sizes for the 400. But I don't know if this is in your budget.
    • Agree Agree x 2
  10. Link
    Feb 13, 2018
    23
Loading...
Similar Threads - 406 400 sbc Forum Date
Edelbrock 1406 on Factory 350 EGR Intake How-To's / Knowledge Base May 21, 2014
Edelbrock 1406 hesitation problems How-To's / Knowledge Base Jun 6, 2012
tips and tricks to adjust a edelbrock 1406 How-To's / Knowledge Base Oct 14, 2011
400 with 350 parts? How-To's / Knowledge Base Feb 26, 2018
1986 regal fuel lines 383/th400/373 How-To's / Knowledge Base Feb 21, 2018
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
