427 SBC
I am running the Dart girdles on my afr220 heads with no issues. Just remember to do the adj with the girdle snug around the studs or one you tighten them all your adjustments will be way off. The girdle really pulls the studs in line.
Thanks for the tip, I have no experience with a stud girdle of any kind at all. I was going to call jegs and find one that will fit my setup. I believe some girdles are provided with their own polylocks and I would like to use what I have if I could.
You will not beable to use the poly locks you have the girdle requires longer poly locks.
Here is a pic of my motor so you can see
