Re: 454 questions
Normal piston
Cyl #6(same as #5)
Closed "heart" chambers
The engine actually turned over pretty easily which was suprising. As for heads they are closed chambered not open chambered. I checked out the head where the piston would have smacked it and it appears fine or atleast it looks like the rest of it. I actually just got a pic of cylinder #6(opposite of 5) and it has the same scratch mark! Im thinking it must be designed that way for some reason.565bbchevy said:Did you try and turn the engine over before you tore into it?
Those heads appear to be just a standard open chamber smog era oval ports which probably
don't flow well. I would personally still look for a set of 049 or 781.
It also looks like #5 piston smacked the head to get that mark, if that is the case it is very
possible that head is cracked. So I would inspect thoroughly to find out what caused that(especially #5 rod)
It also appears that it blew a head gasket or somehow got coolant in your end cylinders.
If you can post some more pics of both heads,block,cylinders etc.
Normal piston
Cyl #6(same as #5)
