When considering piston domes you also have to figure in deck height which I run 9.78 which puts mine at zero, you don't want your pistons down in a hole and usually used heads will need some milling to get them perfectly flat again which will change the cc of the head.
Most likely your head gasket will be around .039 thick (standard Fel-Pro)
I'm thinking the piston head volume will be closer to -21.00cc to -24.00cc range once your machine work is done.
If you are planning on buying new rods also and since you already need a crank and pistons I would try to find a balanced rotating assembly kit which will save the additional cost of balancing(could be 200-300+) than if you gather separate components from different vendors.
