I found a 1999 5.3 Vortec motor on Kijiji for 800 dollars. What trans would be used with this motor and would the 7.5 handle it and what would you do with the wiring harnesss?
-83MONTESS- said:Is the $800 with the wiring harness? Do you plan on leaving it stock with FI or going with a carbed setup? Oh and the 5.3 is 325 cubic inches 8)
Well if it does bolt up then you'll have to switch to fuel injection. I don't think you can use those with a carb.YGspider said:Also another thing I was considering was a 3800 supercharger... one is on sale for 250 dollars would that fit onto a old 3.8???
307 Regal said:Well if it does bolt up then you'll have to switch to fuel injection. I don't think you can use those with a carb.YGspider said:Also another thing I was considering was a 3800 supercharger... one is on sale for 250 dollars would that fit onto a old 3.8???
And then you'll have to figure the pulley out.
