5.7 vortec install
LSCustoms
1,726
13
Dave V said:
96 setup is different indeed you may need to do some mods to get it to work. i have a 91 silverado setup with all the truck brackets and they work find. only thing nice about the 96 motors is they have the better a/c compressor....
I suggested the 90-93 caprice front setup may work, what do you think?
20,419
do you know if the 96 compressor fit the older serpentine set up?
Dave V
958
no it wont its too big you woud need the newer brackets....been there tried thar
Dave V
958
it may fit so would the 88-95 truck brackets just not sure how it would bolt to the block it should boltup...
20,419
thanks
rlsllc
Sep 24, 2007
88
Ohio
I put one of these motors in my 1999 AWD Safari, it is a great motor.
I will say, the front of the block is a little different, I was unable to use the left over 1999 power steering and a/c bracket on my 1989 350, but it was long enough ago that I don't remember why. It had to do with the bracket with the lifting eye on the front left of the engine. On the same token, I'm not sure if the older bracket will bolt on to the newer enging.
I have a 1999 4.3 and an older 305 out in the bone yard, and one each of an older and newer serpentine power steering bracket, maybe if I get a chance I'll check it out this weekend.
Dave V
958
Well thanks for helping out and solve the mystery a bit......
Aug 24, 2011
4
LSCustoms said:
most people do newer motor set ups, so i will have to look into this... all of the 4.8/5.3/6.0/6.2 stuff is fairly easy to adapt...
for example (with the 4.8-6.0), you would use the trans dapt 1" set back engine plates, to help clear the steering box... what made you go with that motor?
well,i'm in the body shop business and i got the complete truck for 400. at that time i didnt know that the lt/ls motor are the ones to get.also i have browsing this site ,will the s10 [v6 vortec] ac/alt/ serpentine work on my engine? whether or not if a/c is on left or right
V6UnderPressure
202
New Lenox, IL
Dave,
How is hood clearance with that truck setup? I was thinking of doing that swap as well. What about the power steering box clearance?
