Guy I am sorry if I am ignorant about these things. This is why I ask for help. I removed the stock original box which was the 605. Again sorry. Which had the stock pitman arm.
I replaced it with a rebuilt monte quick ratio box. My arm I pulled off the old box was to small to fit the shaft. So using advice I got here 8 brought the allstar performance 56357 arm. But after comparing the small shaft arm to the new arm. The new arm is longer. Which is where I became concerned. So after reading this thread am I ok to use this arm after all?
And Jim thanks btw I know life gets busy and I appreciate all of your help.
Also thank you Steve for taking the time to look up that chart. And for explaining what you did.
So I am guessing the size difference is where the boxes output shafts sit....
the new arm is the right one, if you had the short on then that was the wrong one. When you have the wheels pointed straight your drag link should be parallel to your sway bar.
