Since nobody has attempted to interpret the title... mother f er ? I would drop the pan, swap the filter, then put the same fluid back in with some lucas. As long as there are no catastrophic clues with the pan off.
what perplexes me is that it worked perfectly fine just a week ago, then all of a sudden not.
It worked fine when the engine was running is what I'm getting at. As in, I put the engine and trans in as of Thanksgiving weekend. Drove it around that following monday. Drove it around last Thursday, and now it don't work. Nothing has changed.If it worked fine before you installed the engine that usually indicates a mistake by the installer, which is something most of us have done and in my case more than once.
timo22 made a good point, you need to measure the gap, it should be 3/16". If you have too much gap then it will not seat into the pump properly and damage the pump. Since you have no idea why it crapped out I don't know why you don't check the gap like timo suggested
Don't transmissions normally have symptoms or signs? It never slipped before, always shifted crisp and firm, leave it for a week, go to move the car, and it barely works.I misunderstood, I thought it worked until you dropped in the current engine. If it worked for a while with the current engine and then stopped working it's the internals of the transmission that failed and you won't know what caused it til you remove the transmission and break it down.
I have no idea. I got it from a guy, decent guy, a year ish ago. Gave it a guarantee and gave me a pan gasket, filter, and a few kickdown cables. And the converter for $125 bucks. I've had it since October of 2016. The trans itself has gotta be from the 70s at least.the Internet has lots of posts about a TH350 suddenly failing without any warning. How old was the transmission?
