7.5 posi unit installation? ????'s
dickeymoore
924
Atlanta,Georgia
I have a 1980 Chevy Monte Carlo with a 7.5 rear end with 241 gears and I'm wanting to install a 7.5 2 series posi unit can I just remove the old complete unit with the gear on it and install the gear on the new posi unit without removing the pinion gear and install everything back? THANKS
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
yes, if you have the shims from the posi carrier in the same position they came out of the other rear end those shims should give you the right backlash. You will still want to check the pattern of the gears and the backlash
DRIVEN
8,074
14,533
*CENSORED*
Check the pattern before and after.
79 USA 1
1,065
2,039
Cheektowaga, New York
Do you have the cups for the bearings that came with the posi? If not, I would strongly recommend replacing the side bearings as the Cup (Outer Race) and Cone (Inner Race) are mated parts. The shim pack in the current rear axle should work fine. Still check the back lash and gear pattern before and after.
dickeymoore
924
Atlanta,Georgia
I had new timken bearings installed on the posi unit with new races also but don't have the shims from the posi unit so will the stock shims work that is in the rearend? THANKS
79 USA 1
1,065
2,039
Yes! Re install the shims from the sides from which they were removed and again check your pattern and back lash before and after.
I've swapped a few posi units on the 7.5/7.625's and by using the shim pack from the axle housing the posi unit was going in to, it fell right into spec.
Hope this helps!
Bob S.
