7.5" Rear, 200-R4 Stock, with a 305 in front
Gonzo1970
Gonzo1970
416
449
#1
Welp, after quite a bit of research I think I am going to go get a 28 spline Auburn Carrier, Moser 28 spline axles, and 3.73's for my stock 7.5" 10 Bolt while the 305 is in front of it. Total cost: Around $800.
I wouldn't mind going to a 8.5 but they're proving to be pretty scarce, and if you Can find one, they're around $1,200-$1,400 Used, and lord only knows if they've been beat to ****.
Point being, I don't think I am going to be near 300HP/TQ anytime soon.. The 305 in it is perfectly fine, and runs like a top. All I'm going to do it is letting it breathe.. an Intake (Edelbrock Performer with EGR (I can block off later, maybe)) and headers/duals.. At best, being Generous, I will be around 220-230HP, 260-270TQ.
The 7.5 with (or without, for that matter) the above mods should handle that with no issues, as should the stock 200-R4. What I am reading is 330TQ for the 200-R4 is its limit, and the 7.5 rear - 375 without slicks and slamming the **** out of it.. I don't abuse my cars. It might see the track once, maybe twice for shits and giggles (15.5 if Im lucky), but its a daily driver first and foremost, and lets face it, I'm not going to win many races, if I did race, with a "breathing" 305.
Logic here sound ok ta ya'll? Thoughts?
Thanks!
-Gonz
1bad79
1bad79
861
688
Allendale mi
#2
The 200-4r when built correctly can handle way more torque than that,in stock form not so much,I run one behind my aluminum headed 455 olds but it was expensive to build,but I like it and it was a fun project
lilbowtie
lilbowtie
2,543
2,354
Canton Mi
#3
If your going to spend that much - a little more and you have something. But -yes it will work.
Kwik_Cutty88
Kwik_Cutty88
Moderator
Moderator
Nov 22, 2011
1,096
481
83
Coastal North Carolina
#4
You should try to find some used 8.5" axles from a Grand National or 442. They bolt right in. Sometimes you can find a good deal on used 28 spline carriers on eBay.
Wraith
Wraith
1,046
2,572
DFW, TX
#5
Nothing wrong with the 7.5" if you ain't beating it like a 16 year old trying to be John Force. I used to drive mine like that but always made sure it didn't/wouldn't hook it hard from a dig.
melloelky
melloelky
1,058
1,621
mass
#6
keep sticky tires off it and it'll last longer.
83StreetMachine
83StreetMachine
Dec 16, 2011
99
100
Central NJ
#7
Gonz, where are you located?
Gonzo1970
Gonzo1970
416
449
#8
wskirvin
wskirvin
175
178
Indianapolis, In
#9
Who rebuilt your trans? i'm planning on running one behind my 455 as well.
Similar threads
