the two pinion gears in the Auburn posi are much smaller than the pinion gears in the open carrier. I blew the two pinion gears in my Auburn by just poping the clutch to chirp the tires to show off at a friend's garage. Pushed the GP in and put it up on the lift and put my old open carrier back in till I found the 8.2 I was looking for.
Auburn's are turds - no rebuilding ???? I never figured out why anyone designed them other than knowing they could leave out the non-rebuildable detail to the consumer and still sell them. They are comparably priced to Eaton clutch, detroit lockers, etc. In a normal world spider gear failures only occur when they are worn out. As built new, they are not the weak link, even in the 7.5. Pinion and carrier bearing size creating instability is their issue.
