700R4 with column shifter????'s
8,221
17,670
So is there a gate in a 1980 none tilt column shift column
76-80 A body non-tilt gate
p/n 7811592
8,221
17,670
At this point, hard to tell. According to the fact there's only ONE part number for all column shift automatic column gates, I'd venture to say yes, but I'm not going to go that far. I obviously don't know enough about column shift cars to be of any help.
1bad79
1,023
890
Allendale mi
All I can say is unless the house starts on fire I’m not going out side in this heat and humidity not even to look at car parts B5B5F6D8-203D-4090-9B36-BBEAEC7734F6.jpeg
hoffa65
319
416
Atlanta GA
It should, i did it.
Adjustment is a bit tricky, best i found is to put trans in 4th and put column in D so it engages the detent plate then tighten the backdrive linkage bolt.
OD will be drive, 3rd will be between D&2, 2 will be between 2&1 and 1 will be to the right of 1.
R will be to the right towards N and P will be to the right a bit but should engage the detent in park
