Saginaw 4 speeds only used the M20 RPO, Muncie 4 speeds used M20, M21, M22 RPO's up to '74. BW T10's used M24.
Yeah, I was actually thinking about the M20 code. Good catch on my mistake!
Ok.
Just so you know,an M22 is a Muncie,not a Saginaw.
Did your pit pack look like this one;
Also,and this is just my personal preference,I would use the steel bushings over the nylon.![]()
Hurst Shifters 3327302 Hurst Pit Pack Shifter Bushings, Buttons, and Clips | Summit Racing
Free Shipping - Hurst Pit Pack Shifter Bushings, Buttons, and Clips with qualifying orders of $109. Shop Shifter Bushings and Clips, Manual Transmission at Summit Racing.www.summitracing.com
If you need any more help,I can recommend Paul Cangialosi,or 5Speeds as he is known.
Here is a link;
He does sell bushings,but he does say they will not replace factory rubber bushings.
He may be able to point you in the right direction.
Might not hurt to send him an email.
Guy
What are so special about his?I have several of those factory Hurst shifters. I modified the one I am using in my car by opening the holes up slightly with an end mill to use Paul Cangelosi's bushings. They make such a huge difference in shifter feel.
They are tool steel. The Hurst metal bushings are soft powdered metal that breaks easily.What are so special about his?
