How smooth is the idle? I know there was some question of which cam was used. I wonder if that carb is super lean? If it is a late 70's carb, you can pop out the aluminum plug in the air horn, which I tap for a threaded plug and I count the number of turns the APT adjustment from its current position, remove and notch with a hack saw blade. I can adjust the APT in 5 minutes, anytime I want. If it is carb related for the miss, I bet one to two turns out might fix it. The other possibility is that an non ethanol friendly accelerator pump was used. Pull the air cleaner, without the engine running, open the throttle by hand and check for two little streams of gas coming out of the boosters. Possible the timing set wasn't accurate. I believe if the timing sets aren't accurate, they retard the cam timing, some by like 8 degrees! That would definitely kill low end power. Something sounds way off still. Good luck.
