That's kind of puzzling to me that a brass sleeve would have less friction than needle bearings......
I checked the original rocker againts the Comp setup and the Straub setup. Man the Straub is SUPER smooth compared to the other two. The Comp setup is a lot smoother feeling than stock tho..
Got really detailed on the block. Broke out some small picks and brushes. Got it pretty clean. I couldnt find the color I wanted for the block in a 2K formulation, so I decided to get super detailed and clean?high temp clear over the bare block. Once cleaned, its the perfect match with the cars finish. I also got a few parts in:
rear main seal, gasket and new cover, ARP bolts
Trick Timing chain dampener bracket, GM timing chain dampener. Early blocks didnt have the provisions for that part
Front seal, Two Piece timing cover which I'm modding for the -10an return lines off the turbos...Holley Low profile oil pan and a few other small things. Still waiting on the Go fast parts
Some pics..
Trickflow dampener bracket and GM dampener mock up
Pretty spiffy....
Cleaned the rear of the block and painted it. New cover, gasket, rear main seal. Not installed yet. Waiting for the billet oil "dumbell" from SacCity Corvette to arrive. I may hold off on installing it-save it for the rebuild later...
A lot of tedious work getting the block to bare metal. Ill be cleaning, cleaning and cleaning a few more times before painting...
Thanks for checking back!!
