79 cutlass drag car
old80cs
632
2,082
Massachusetts
Only thing I’d recommend is a good set of aftermarket push rods. Way back when my friend bought a crate LS7 454 and we pretzeled a bunch of pushrods in his mud bog truck. That engine hammered right out of the crate and was even better after he reworked it with porting, roller cam w/ rev kit, Victor 454R intake and a Predator carb. Good times...
bracketchev1221
1,421
1,665
Glad to see it’s moving forward. Make sure to degree the cam in and don’t forget to check your piston to valve clearance.
Genoapb
20
39
13
Grand Rapids, MI
Definitely and I will ask the builder what push rods. Project is snowballing quickly! Decided to sell the stock iron heads and go with a set of aluminum ones.
bracketchev1221
1,421
1,665
Generally I would go with .080 wall chromoly pushrods. But you’re going to have to check for length.
Genoapb
20
39
13
Grand Rapids, MI
Yeah, after he setup my heads for the springs. He wanted to check for pushrod length. Which is kinda how this started spiraling and snowballing. I figure why put all this time and money into the stock iron castings if I can shed 100lbs and make more power with aluminum and hopefully even recoup some of the money by selling the stockers?
bracketchev1221
1,421
1,665
Yes, the aluminum heads are generally 75 lbs lighter than steel. And you are right, if your steel heads NEED work it can start adding up. But with that being said, if budget is an issue, I would not be afraid to use the stock heads. We had stock steel heads on my dads 427 in the mid 80's and did go a best of 10.12 with them. So they can support decent power. Granted we did go faster with a set of AirFLow Research prepped GM aluminum d-port heads.
Genoapb
20
39
13
Grand Rapids, MI
Set the big single plane on but decided to pull the trigger on aluminum heads. Waiting on assembly. Going to be slow going at this rate.
Genoapb
20
39
13
Grand Rapids, MI
Slow is be
Slow is better than not at all.
True! Local buider got the heads done in a hurry, picking them up tomorrow and am stoked to start assembling what I hope will be 600hp beast! I also verified for sure I've got the forged goods in the bottom end!
Genoapb
20
39
13
Grand Rapids, MI
My awesome wife picked up the heads for me. Now I'm just waiting on the pushrod length checker tool and degree wheel and bigger oil pan. So I can check everything and start assembly!
