Well finally I got some pictures to put up here. My last post basically summed up what I've done since the last update, except for me putting the engine together for good.
PRC LS6 243 heads CNC ported
Painless 60608 integrated LS swap harness w/ fuse block mounted in factory location
Engine harness :shock:
Dakota digital dash
I ended up mounting the control module for the digital dash right behind the radio. The module is about 4x6" and has a ribbon cable to go to the cluster.
Engine sitting in it's home for a couple days
BRP LS swap headers
B&M trans cooler (forgot the exact size, it's the largest they offer)
and custom radiator support x-braces to clear the cooler
C5 Corvette filter/regulator assembly
Conveniently, you can't see anything behind the grille
FLT Level-4 4L60E and Yank 3600SS stall
Fixing the heaterbox that I knocked a hole in, impatiently putting the engine in by myself :?
I decided not to smooth it and what not, that will be hidden by the coil packs anyways and it will be time wasted at this point.
Cutlass hinge covers FINALLY put on the seats
That's all for now, I've also replaced the crappy BRP trans crossmember with an Iceman Racing crossmember that bolts right in. Hopefully I'll have the engine and trans dropped into the car tomorrow so I can start buttoning it up and get it on the street this year.
Thanks for looking everyone
Dakota digital dash
BRP LS swap headers
