holy shoot!!! Will do on the next one.Here's a trick for you to learn..
Use the whole new Bearing to install that Race, as well as the other one. Put it on the Bearing, put them in the freezer for a couple hours, goes right in. 😉
I have a hone on order to make the old inner into a setup bearing; should be arriving today. Thanks again for the input!!!Something like this works extremely well. It's small and can be rotated to watch the torque while spinning. Snap On makes one that uses a light that can be set to illuminate a desired setting - it's pretty slick, but $400.
Dial Torque Wrench Needle Indicator Cursor Tool 0-100n.m 2-direction 33*10*8.5cm | eBay
Find many great new & used options and get the best deals for Dial Torque Wrench Needle Indicator Cursor Tool 0-100n.m 2-direction 33*10*8.5cm at the best online prices at eBay! Free shipping for many products!www.ebay.com
Using a fish scale is 'old school' and effective, but takes a fair amount of space.
What I meant by it will seem tight is that 25-40 in/lbs of rotational torque will not spin freely by hand - in my opinion it feels tight, almost too tight. But it won't be.
I'd strongly recommend making a setup bearing for the inner pinion.
I used the 64-72 upper control arms on mine as the G body ones weren't long enough to get the pinion down into the negative numbers where it needs to be.I'm also just now catching up on this thread. Others such as Clone Tie Pilot, GNVAIR, and RT Jam have mentioned the Ford Crown Vic rear and coincidentally I've been reading up on it lately. Another member, tokarz1 did a real nice job setting his up.
I was looking at using a shortened P71 Crown Vic aluminum driveshaft in conjunction with a B Body differential, as I'm considering using that instead of an 8.8 from a Fox Body Mustang. That reading led me to a few people actually using the whole Crown Vic diff (up until '97) and upgrading the guts, and one of those people is tokarz1. Apparently the Vic's UCA ears are in almost identical positions as the G Body (Mustang isn't), the lowers are also very close, the spring perches are off by 1/2", and the rears are fairly cheap and plentiful since they're in multiple cars. They're a bit wide and need shortened, and it seems that using UCA for a 73-77 A Body would be beneficial.
8.8 rearend build
I know just like the 305 build not everyone is going to approve of what I'm doing and some will feel it's completely sacrilegious and that's ok, everyone likes what they like and are free to state their opinion and do what they like on their own car. I enjoy building things, the planning...www.montecarloss.com
I am making the old bearing into a setup bearing.HIGHLY suggested. Agree with this completely. The rear pinion bearing closest to the gear is what he's talking about. If you don't use one during setup, and you miss on pinion depth, you'll might be buying a new one anyway
Hey, thanks so much for this! I sincerely appreciate this.You're better off to do the carrier bearing pre-load first before messing with the pinion stuff. Pre-load for the carrier side bearings is set by the shimming without any specs to check with a torque wrench. Just a 0.004" thousandths thicker shim on either side from just slight drag and that's your pre-load spec from the CSM. MANY experienced guys go by feel and if you do it for a living, then you know what that feel is. Regardless, it should rotate smoothly but not spin around like a pinwheel.
10000812. Need 2. I believe they're for any G-body and some older A-bodies, but don't quote me on that. I know they fit the 8.5 442 rear.I am making the old bearing into a setup bearing.
Do you know the part number for the bump stop on the rear axel.
I've only found this (mislabeled?), and I don't want poly (want OEM rubber).
