Thread file may help.
In the case of the yoke may have to try google and see what the threads may be. Most likely Metric M8x1.25
I tried the metric bolts, both fine and coarse - neither worked. Ran a 5/16-24 tap through the holes and the new bolts thread-in correctly.Thread file may help.
Preload is not the same as turning resistance.
An 0-80 in-lb beam-type torque wrench.What are you using to measure the drag on the pinion
I'm just sharing... didn't expect nil resistance. Was hoping to get a bit of practice with reading the torque wrench while spinning it. I've become very farsighted in the last two years and I can't see s*** up closeIf you have used bearings and gears they won't as be tight as new ones. That's a no brainer...
