8.5 rear swap
mrapii
198
Waipahu, HI
Won't work, only G-Body 8.5"s swap in.
zerex
41
6
Yah it's not listed as a swap candidate on any website. I would bet all the mounts are either in the wrong place or wrong angle. I would bet wrong place or someone would make arms to fix the angle problem (for example the arms to fit a 12 bolt out of earlier g-body/A-body).
let us know what you find out though. What type of B-body did you find it in? I would guess a Cop Car Caprice? Since all the B-bodies I have seen have had 7.5" 10 bolts but havn't had a chance to see what a caprice with police package had.
elementoleflows
23
will a rear end out of a 3rd gen f-body camaro bolt up without a problem? or will i need to change or modify anything?
mrapii
198
Waipahu, HI
Nope; only G-Body rear axle assemblies swap.
elementoleflows
23
what car out of the g body family has the best or easyer to find rearend with good gearing and strong enough to hold with a built 350
steve 86
44
hamden ct.
use a locker they will help any 7.5 rear.
steve 86
44
hamden ct.
its a spring loaded coupler that you put where thespider gears are,the force of the rear spinning locks the axles together......it kinda looks like a spool when installed. its kind of hard to explain without showing.
it does unlock when you turn and sometimes make a clicking sound, but hey,its worth it for the result of an absolute positive posi.
if you use 85/140 it keeps it pretty quiet(when turning). it doesnt make any noise usually.
did i mention you can only use them in an open rear?
