Exactly. If you’re running stock accessories, then you should need the amperage limit of the fusible link.
I’ve done 3 g-bodies with aftermarket EFI running the stock accessories. But I have no HVAC in any of them and no power seats either. All have had power windows. I run a 40 amp fuse that is tied into both 10 gauge factory wires. I mount the in-line fuse almost directly behind the intake for easy access.
All of my EFI connections and fuel pumps are powered separately directly from the battery.
I can’t say that what I’m doing is correct, but it has worked. I’ll also add that my body to frame, engine to frame, and block to battery grounds are not even remotely questionable. I ground the rear mounted fuel pumps directly to the battery with 10ga and I have #2 wire from the engine to the battery. All of the grounds are new wire - don’t trust any 35-40 year old ground wire.
