Thanks for that info! I don't want to sidetrack your build posts, but one last question on the Anti-Hop bars because I have not come across this for a G-Body. Did you have to modify the 3rd member housing? My original GM rear end and the new FAB9 are quite different from what you have -- the wide UCA rear "jaws" slide over a bushing mounted onto the rear end casing (see pictures). I would suspect that you had to cut that off and weld a different bracket...
