80s camaro universal bell housing????
bigblockfrank
208
4
51
mt.vernon, ky
Will it bolt up to my olds455 and I'm going with 11 inch clutch? Also will a t10 Muncie bolt to the bell?
Reason I'm asking, I'm going to adapt a ls1 t56 to this bell.
It suppose to be universal fit chevy BOP. My main concern, can I use it with 11 inch clutch?
You could begin by posting the part # of the bell housing. Maybe then someone with more knowledge would know if it was capable of fitting an 11" clutch and flywheel.
Longroof79 said:
Here's another one that might be right up your alley http://www.ebay.com/itm/Buick-Oldsmobil ... 7053767%26
i guess ill go with old school t10 bell housing, heres a part list i have gathered so far. if anyone has done this please chime in, if i need add anything.
lt1 t56 $1200 i already have
BOP t10 m22 bell for 11inch clutch $150
ls1 input shaft $200
ls1 input shaft bearing race $22
t56 adaptor plate $201 bolt the lt1 t56 to the old school bellhousing
flywheel $300
pressure plate 26 spline 11 inch clutch $250
bolts $25
extended pilot bushing $30
gbody 4 speed pedals $100
im still debating to go with external slave cylinder or internal. internal i thinking hard at $135
i have the master cylinder from the lt1 1997 firebird and hardware.
if you play you pay!
flywheel $300
bolts $25
Ouch! It'll be fun when it's done tho. I'll stick with auto or factory manual Gbody, I'm too cheap for anything else lol.
