Speaking of glue Jim, what are you using to remove it? I will be attempting to recover mine at some point. I had it professionally done over a decade ago and the glue is still holding strong.Thanks for the tips Jack, right now it's pretty time consuming getting the old glue off. Once I get that, I'll get the wife to help like you said.
That's a good tip, Brian.Headliner board cracks....the way I fix them is with the plastic scree.mesh like is used for drywall , covered with epoxy on the top side.
I actually use a product that we use at work for repairing bumper covers, but it's essentially the same as what I wrote above, and the drywall screen and generic epoxy are probably cheaper to buy than the "professional" stuff
The fiberglass hairy strands, or even the gorilla hair...whatever they call it, should work very well. I also had to re-drill most of the holes for the sunvisors. I forgot how I lined them up. I think if you can hit at least one hole, you can use the sunvisor as a guide to hit the others.Jack, it doesn't say anything about thinning. We'll see how it goes.
I used 5 minute epoxy, mixed with some fiberglass hairs to fix all the cracks. The epoxy melded in with the foam awesome! But, the visor corners were so jacked up, I had to rebuild them. I. Doing so i took away the holes. Now I have to figure out a way to located them, without putting the headliner board in.
Hmmmm. Going to finish prepping it tonight so I can glue up the material.
