Re: 81 Century/GN Wagon build-up New Pics! Update 11/25/13
I would love to hit Detroit!.
I keep on reading through trying to compile all the info. As i have the complete spindle set-up for the front, calipers, rotors (used crap), spindles, dust shield etc. The rotors are only 10.5" Dia, but the benefit of dual pistons is there. According to a few on the MCSS, and pro-touring forums, it is an improvement over the stockers. But, I already have the C5/LS1 12" rear brakes, so I pretty much have to go with 12" LS1 or the bigger C5 brakes for the front to keep the bias in check.
With some more reading, there appears there was some sort of clearance issue using the 12" LS1 rotors and PAD/calipers on the Blazer spindles. I couldn't find any pictures. The clearance is obviously greater with a larger rotor, since it pushes the PAB out farther. The Camaro PAB and C5 PAB apparently have differences also. Somewhere with how it is mounted to the spindle. maybe longer of a different offset.
In any case, I will be getting the C5 13.5 Inch rotors first, and taking it from there. Rock auto has the calipers and PAB for about 100 per side, less if you have a core. So some of these guys trying to get 300 for calipers and PABs are crazy, lol
