I have done a 7.5 with 8.5 28 spline axles and late style posi...figure $275 for the posi and $275 for axles....good to 11.50s before it let go...by the way, it has c-clips. The 8.5 is $850-up I have never been able to find one complete for less...still has c-clips. I did an 8.8 swap, wonky geometry, Mustang back wheels...then bought a Baseline Suspension swap kit was $320 to correct the upper control arm deal, then some weld on mounts for the lower control arms for $120. Oh, then $270 for 9 inch 31 spline axles and $80 for 9 inch axles ends that would accept the 8.8 rear disc brakes. Then $120 for a 31 spline spool plus some bearings.
The Chevelle 10 bolt and 12 bolt deal also requires geometry attention and now everyone thinks those rearends are worth $400-$1200...still has c-clips and the same size 28 spline axles, AND requires a funky offset rear wheel to work and never looks right.
I tried all the cheap ways...just buy the 9 inch and be done. 31 splines and a dirt track spool with normal gears went as fast as 9:90s with a big block no issuse after almost 10 years of abuse. Just stepped up to big axles, aluminum pro bolt thru case etc to go with a 632 its around 5.20's in the 1/8th now with the same housing, we did add a back brace.
