My budget is 2 grand for the suspension and if i need to go over I will but can you send a link to the umi one i would love to check those out i am in need of new control arms too"that won’t break the bank" you must be kidding. The list from carnutjw is a good one. Add that up and it has to be over 1500. UMI frnt/rear coils and shocks are only 835.
Why do you need control arms? Which ones-front/rear- upper/lower? Here's the UMI stuff to peruseMy budget is 2 grand for the suspension and if i need to go over I will but can you send a link to the umi one i would love to check those out i am in need of new control arms too
To be honest i just think i need to replace the entire suspension i need to take a look at it all again but it’s mad squeaky and the last owner had the car dropped on spindles all around and i don’t like it this low like i said i don’t know much about all this stuff and i just wanted to get other peoples opinions before i go blowing money on everything and when i took the car to get looked at for safety inspection they said that they will pass it but if i were them i should get new control arms🤷♂️Why do you need control arms? Which ones-front/rear- upper/lower? Here's the UMI stuff to peruse
My current combo, sort of on the cheap- Moog 5660 front springs -1/2 coil (598lbs/in), Moog 5401rear springs (129lbs/in) about $60/ pair($120), Proforged +1/2 " taller upper and lower ball joints $50 each($200), Summit front upper control arms ($330), splurged on Ridetech HQ single adjustable shocks, got a deal on those, they are usually pricey($740 retail/4 ), but some have good results with Bilsteins at about $85 each. Front stabilizer bar is 1-1/4" factory style with energy suspension hardware and bushings and rear is S10 Blazer, factory rear would be okay. I'm very pleased with it for what I've got in it. You should be able to put together a similar setup for about $1000-$1500 or so. Oh I almost forgot, a 12.7 ratio steering gearbox helps a lot too.![]()
High-Performance 1978-1988 GM G-Body Suspension Kits and Components | UMI Performance Inc.
Discover premium performance suspension components, handling kits and lowering options for your 1978-1988 GM G-Body at UMI Performance Inc. Engineered in thewww.umiperformance.com
Sure thing i will give you a call this weekend !Call the shop, we will hook you up.
Pretty common for the front upper control arm bushings to be worn out. The arms may be okay, but just need new bushings?? Or you can get replacements pretty cheap.To be honest i just think i need to replace the entire suspension i need to take a look at it all again but it’s mad squeaky and the last owner had the car dropped on spindles all around and i don’t like it this low like i said i don’t know much about all this stuff and i just wanted to get other peoples opinions before i go blowing money on everything and when i took the car to get looked at for safety inspection they said that they will pass it but if i were them i should get new control arms🤷♂️
It may be the bushings i remember someone saying something about themPretty common for the front upper control arm bushings to be worn out. The arms may be okay, but just need new bushings?? Or you can get replacements pretty cheap.
