82 Cutlass Supreme 307 Temp Light
jeo1980
n00b
Aug 29, 2017
2
We are having an overheating issue on my buddy's Cutlass. He was driving it last week and the temp light came on. The motor felt hotter than usual too. We changed out the thermostat and it didn't fix it. He changed out the temp sensor and the light was still on. We decided to try the water pump, that seemed to cool the motor slightly but the light stayed on. Last thing we changed was the fan clutch which didn't fix the issue either. Only part we can think of next would be the radiator. He did mention that he hit a bird earlier in the day hours before the light came on but we didn't see anything when we removed stuff for the water pump. Any ideas on what could possibly be causing the issue? The crate motor doesn't have but around 60K on in the last 20 years.
8,826
7,779
The Olds 307 is easy to cool. Unless you are loosing coolant, it should not be overheating. Buy an infrared temp gun and see what the temp actually is. Check the A/C condensor for damaged fins from the bird and limiting airflow. A cheap aluminum/plastic parts store rad will easily cool a 307 if it is running hot.
20,391
did you check the temperature with an inferred temp gun? Maybe it's a simple temperature switch that is defective....but I kinda hope it's not after all the parts your changed..... :popcorn:
jeo1980
n00b
Aug 29, 2017
2
Thanks for the assistance from both of you. We checked the condenser and it looked fine, still have to pickup a temp gun but, just from standing over it the temp feels cooler. The light is still on and now it has a sputtering sound; no smoke from exhaust and oil/coolant look fine. I checked the exhaust and it didn't look or feel like there were any leaks but, could possibly be clogged. The noise comes from the area of the exhaust manifold pipe and the flywheel area. Only reason I bring that up is because my buddy is being told that the exhaust could cause the light too and I have little knowledge on this. Thanks again for taking the time to assist.
20,391
I always confirm any abnormal reading on a gauge or a warning light before I go any further...
LeftLaneOnly
294
490
Check the cat with that temp gun mine was clogged and really heated things up
It blew out the donut at the manifold and an exshust manifold Gasket
8,826
7,779
Was 82 the big converter or did GM switch around that time? My old 81 Delta 88 had the big restrictive "pancake" converter that started plugging.
