Other misc. crap that happened today:
Ordered new power steering pump with res on it just cause
Ordered new p.s. pressure line cause I'm losing fluid somewhere and new is better
Found out my drive shaft has probably never been out. Took the U Bolts off it to drop the drive shaft before pulling the motor/trans and it would not budge. Debating on leaving it or heat it and beat it and replace the U Joint.
Also found out this thing was shoddily put together. Motor mount bolts were only snugged down, transmission wasn't even bolted down, just sitting on the mount. On their defense, the bolt holes didn't line up, so I'll have to fix that some how. Maybe widen the slotted holes on the mount so they stretch far enough to actually be usable. There's also way too many body shims for the fenders. Drivers side isn't even flush with the rest of the cab. Put that on the fix it later list. Exhaust manifold bolts were only snug. Was about to have two fall out on the pass side.
Mucked up my front clip a little. My engine hoist needs a longer boom.
Fixed the vacuum (really that's how you spell it? sheesh...) line going to the transmission, just kinda bent it straighter to match the lines of the block and transmission. Now it lines up nicely and has a much shorter hose on the tail end of it.
Decided I need to buy new transmission lines. Cut up lines and rubber hose with hose clamps just don't do it for me. Now I just need to order some and put them in.
While I had the empty engine bay, decided to look at all the plugs and zip tied the majority of them to the harness going to the computer. Pulled the one wire going to the electric choke out and fixed the wire going to the dis with a butt connector. One down, three to go. Starter wires that are way too long, I'm looking at you.
Also kinda damaged my starter pulling the motor out. It got hung up on the motor mounts, we lifted some more, still hung, drop it, shake it, still hung... Eventually got the whole mess free, but put a nice crack in the aluminium of the starter. It had a dead spot anyways so was going to get replaced but still... was hoping to use it to at least fire it up for the break in.
Picked up electric fan and fan controller. No more mechanical fan taking up space and cutting off fingers in the engine bay. I do still have all my fingers though, which is good. It should fit nicely in the cavity infront of the radiator. Even if the O'really? catalog says it doesn't fit my car. It's bigger then the two listed and still smaller then my radiator core, it'll fit.
Still on the list, replace courtesy lamps with LEDs to match the dome light, find out if my speedo drive needs to be swapped out (might be important), get new tires to replace the weather cracked dry rotted tires, order in the rest of the cheap gauges I need to customize my dash from long sweep to real guages, make a plate to hold gauges and rip apart the dash to get it all installed. I'm sure there's more, but work is in seven hours so it's time to stop rambling and get to sawing wood.
Just to share. And this post needed a pic.
