I love the stance as well, but with the wider front tires, it rubs at the top of the wheel arch. I knew I should've gone with a skinnier size, but they just look so good, I couldn't help it. They are the stock V6 springs, and I don't think they like having the extra V8 weight on top of them... I know of quite a few people that still run them with V8's, but none of them that I have seen have wider tires up front like me. The plan is that it will hopefully pick it up enough to where it doesn't rub. I'll also be giving it a slight 'massage' with a baseball bat to roll the edge.
I actually started on it today after work, and got the brakes, shocks and sway bar links off. The nut for the lower ball joint came loose with no problem, but without a pickle fork, I was unable to separate the lower ball joint from the spindle. I soaked it with some penetrating spray and rapped on them with a hammer a bit, but no luck. Then I got a call asking to fill in at a trivia gig, so I threw the rotors and wheels back on and set the car back down on the ground, got cleaned up and took off.
I'll snag a pickle fork from work tomorrow, and hopefully I can get at least one of them in after work, before I have to go to trivia again.
I've got my fingers crossed that I can get it apart without ****ing up the boots, because I really don't want to mess with that stuff right now, I just want to take it apart, and put it back together...
I'll need to buy new shocks, since I broke the tops off to get them out, and sway bar links, which suprisingly came apart. The lower control arm bumpers are smashed, but I think I have a set laying around that I snagged off of the same MCSS from work that I got the springs from. I was thinking of just turning the rotors, but now that I looked at them today, I think I'll just replace them, and get some new pads as well. Calipers and hoses I already have, and I guess that means I should check the rear brakes too...
I just wanna drive the thing!
