83 el Camino ls swap
can you take some close up pics around the heater box? what motor mounts did you use?
thanks
thanks
When I get to the shop tomorrow yes I can, I didn’t touch the heater box or anything had to modify the drivers side firewall a bit for my headers to fit, I used regular stock gm motor mounts from advance and then I bought summit racing sbc old school clamshells ( that were expensive as hell and for word of advice how we modified the cross member we took it off the vehicle cut the piece off that bolts to the trans, turned it upside down and welded it and it bolted right up
Reactions: Injectedcutty
Dual electric fans installed, put the stock radiator shroud on to hide them, tuner never showed up waited on him al day just ordered upper radiator hose we will have to custom make a lower still waiting on the fuel system to come in for suspension I don’t think I’m going to do a big upgrade just gonna do ladder bars with a posi and gear upgrade I have a 10 bolt rear but I am not sure what style I have will continue to keep y’all updated as we go
Been working so much have not had time to post, we got the starter on, neutral safety switched wired, transmission lines Plummed, made a new custom dash harness for my new dash, I need a fuel pressure regulator hose, got the computer work done still need to make the custom fuel sh*t you don’t need an expensive *ss setup we are using my stock el Camino tank, got the car to crank today but it wouldn’t start nor run bc the fuel isn’t hooked up I will keep y’all updated
Reactions: fleming442
Ok so I had to buy a smaller pulley for something bc it was hitting my power steering pump, I forgot the PN Bc it got lost in a fb post does anybody what belt may fit?
New oil pan, front clip back on just got the driveshaft back,she’s sitting a lot higher than she did with the 350 sbc, now we are starting to do the wiring we need a little help does anybody have an ignition wiring diagram or something to go off
What oil pan did you use?
Finally!!!! Someone that actually used the pan! Lol but ive been thinking about getting the 50239 one(grey colored) but didnt come across anyone that bought it and installed it. How did it work out for you?
It’s great no leaks part of it does hang off the end of the trans but that is just the thick part I had to use the old bung out of the truck pan to get the oil filter to screw on bc the one that came with the pan won’t work and jegs Does not list that filters to use I also am using a low profile small filter so if anybody looks under neath they just see a nice new pan and filter lol
