ok. ive been busy!!!! i picked up a posi rear end with a fresh rebuild , moser axles, and a motive perf 3.73 gear. all for $200 i also picked up a BIG END PERFORMANCE 2200 stall, BIG END 110 gph fuel pump( made by holly),SUSP TECH poly sway bar mounts and end links, TRICK FLOW diff cover with a built in brace (this thing is sweet!) UMI upper and lower rear control arms. Eibach springs, Koni adjustable shocks, MSD wires, (needed angled plug boots to fit around headers) B&M deep trans pan, and i know im forgetting alot. pics to come. I cant wait to take it for its first ride.
Re: 83 olds wagon build thread.(granny's revenge) NEW PICS
heres some more pics. i bought Eibach pro springs for a gbody and because the wagon is heavy in the *ss it made the back sit lower than the front. soo i picked up some s10 2in drop spindles and put them on the front and the results are a mean *ss looking low wagon that handles like its on rails!!! let me know your thoughts. and it rides good for being that low!!! i used the following parts for the susp. Eibach gbody pro springs, Koni adjustable shocks, DJM S-10 2in drop spindles, Monte SS BIG front sway bar with Susp Tech. poly mounts and end links, Monte SS rear sway bar with new grade 8 hardware, UMI upper and lower rear control arms, and last but not least Susp Tech. poly front control arm bushings.
