thanks! No worries, minor setback and I get to do my first rebuild....I'd say you found your issue. A dead hole and a noise coming from it isn't a coincidence. Time for a 350. Sorry man
now i just have to upgrade that crappy TH200 also.
i will look. he says if the flexplate was cracked the noise would change when we put the car in gear, but I dont know.
its sounds more violent than that but i will double check. also, i forgot to note, when i pulled the plugs a few weeks ago, #8 electrode was bent all the way over and touching like if something crushed it. right before i took it to the exhaust shop, I put new plugs and checked the gap. he pulled #8 and said it was soaking wet and not firing, but wasnt bent? i dont know how its related, but the noise is coming from right below that cylinder.
could be coincidence or another problem
i found a guy up by Orlando with a 78 Olds 350 fro $400. he said it ran when he pulled it to upgrade. its still all Gold, including valve covers. i may pick that up and rebuilt it, then just swap it in. that was always my plan, just not as soon as this
i am waiting for him to send me serial # and casting #'s to confirm date, etc.
I have heard different sounds from a cracked fleplate, I have heard sound like a bearing knock and like a scraping
When you find a problem like you did with #8 you need to stop. Those problems don't go away no matter how much you ignore them. If you want to keep the engine and rebuild it it is always cheaper to do it before the engine blows up.
I havent dove in yet to troubleshoot so im not sure Brought it home from exhaust shop and its been sitting. I been working 7 days a week but im going to start looking and disassembling tomorrow after work. I will check thatare you getting oil up to the valve train?
I will know tomorrow hopefully. Im pulling valve cover and will start the inspectionToo high pitched sounding to be lower end, in my opinion. I think it is a lifter or a rocker bridge.
