REGAL 84 Buick regal. Spring updates
Received my engine in friday. Im storing at work until i can finish restoring all the misc parts and pieces i am transferring over.
Heres the engine all wrapped up
So according to the paperwork the block casting is 395558. I looked it up and its a 69-70 350
It has two different heads though according to paperwork
411929 - which is a “8” head from 73-76 and a 409147 which is either 7 or 7a from 71-72 based on what the internets tells me
I have unpacked and confirmed all the numbers yet i just peaked in there today to find the paperwork
Will my current intake that was on my 307 work with this engine for the time being?
307 Chevy.......yep
Reactions: fleming442
307 Chevy......never heard of it?
Reactions: Injectedcutty
Not sure I'd be cool with mismatched heads. You may never feel a difference -- just general principle for me.
Edit: I just looked it up and the 7 and 7a heads have 64cc chamber vs the 8's 79cc. That's potentially a huge difference in compression ratio from bank to bank. Any chance there is a compression test and oil pressure sheet in the crate? I'd definitely be calling the builder before I moved forward at all.
what does his reman olds 350, and blown up 307 have to do with a chevy 307?
Not sure where the sbc 307 came from. The intake will work but will severely limit top end. I used the SP2P(tiny triangle ports)intake on an Olds 350. Part throttle was amazing but the Qjet overwhelmed it at full throttle. It would do nothing for a few seconds then catch up slowly. What is the big casting number on the shelf by the oil fill tube? With the #8 head and 24cc pistons, the only affordable cast pistons available will give 7 to 1 compression, 8 to 1 with a 7 head, maybe less for both, they sit way in the hole. Another early head would be a good idea. Most get 68 to 70cc for 7/6A heads stock. I have measured 77 to 78cc for the #8 heads. Honestly the #8 would need a .040" mill and a bowl hog under the exhaust valve to equal the 7 head. Edited after rereading it.
My mistake!!
