84' Cutlass pro touring build
Very nice! Love the build!
I plan on doing the same setup for the brakes. As cheap as they are it’s interesting that more people don’t go that route.
Reactions: Tony1968
Thanks guys
Curing the high temp clear
Agreed! It's relatively easy to do. Parts easy to get. And much less expensive than many setups out there. I'm sure for what I want to get out of this car that I will be very happy.
Good view on DA shocks. And the big brake adapter. Along with a view of the cut dust shield. I used an old timer method to get hybrid coil overs installed. Big chain wrapped around the frame and between and under wheel of the Jack. I tried to put 6.1L in place last week and it wasn't enough weight to compress the spring. That harbor freight 3 ton Jack you see in pics is a nice tool for the money. Nice sturdy rubber surface on lifting point. Put that kinda even with the shock control arm junction wrapped up the chain using an old towel on the frame to avoid gouging the chassis paint. Nothing I'm telling you guys you don't already know about and I am jumping around and leaving steps out because I know 99% of you guys don't need to see me pack the bearings and mount spindles.
Reactions: Streetbu
I meant to have a crazy smiley face at end of last one 😆
Enough for tonight. Tomorrow, hopefully, a lot more of the front end stuff
