I drilled out some spotwelds and sawzall'd a good chunk of the rotting t top panel this afternoon.
I tried to be conservative, not go too far, so I can assess and cut as needed
The decision I have to make is, should I remove and replace the entire area covered by the repair panel?
The benefit of "cutting it in" would be keeping the trim clip retaining studs along the top of the windshield.
The benefit of removing the whole panel is much less cutting and fitting. Less welding, better contours and less body smoothing.
What say you?
I'll add pics soon.
What say you?
I'll add pics soon.
