Would these work?
yes sir those are perfect! thanks for the link!
Would these work?
got it on ebay from gbodyparts. its the 83 84 hurst olds dark maple I think its called? I guess its a vinyl dye to be more precise.what paint did you use?
That's a new one on me. I'm interested to see that you find. What goes in that square hole to the bottom left? I'm thinking the FO would be some sort of switch lighting.... gray wire is dimmable if that helps.Anyone know what this thing is behind the instrument panel? what it goes to?
The grey module contains a small lamp and blue filter, and the "wire" coming out of it is a fiberoptic line. Where is it trying to send the blue light?
my first thought was the hi beam indicator, but I just don't see anywhere to put the line.View attachment 90442
The end of that fiber optic line goes to the side of the headlamp switch. A lot of times that grey pod is melted and brown and deformed because people use the wrong bulb in it. IIRC, there's a specialty bulb inside used for the fiberoptic. It's been a long time. Don't recall the correct bulb number that goes in there. I recall buying one from the dealer once...many many moons ago.Anyone know what this thing is behind the instrument panel? what it goes to?
