86 Buick regal engine swap
Yaboigbody
n00b
Mar 19, 2018
Hi, so I recently purchased an 86 Buick regal with a 307 olds v8 engine in it with custom side exhaust pipes. I'm definitely gonna stick with it as long as I can until I accumulate enough money to do an engine swap but I cant figure out what engine and trans to go with that'll be good with a low budget, I'm hoping to get one that pushes over 300hp.
MrSony
6,831
6,741
Des Moines, Iowa
Easiest by far would be an oldsmobile 350. same size and rough weight as the 307, all the hookups and brackets are the same. exhaust is the same. water pump, everything. It's dead nuts easy to build a 300hp olds 350. The "good" non windowed blocks are from 68-74ish. Good olds small block heads are #3, 4, 5, 6, 7, and 7A. Not 7A, those are crappy 307 heads, which you probably have. Look for the tiny A. 350 olds .030 over with decent hyper pistons, 9.5:1 (pump gas friendly, depending on where you are, if you have 93/94 at the pumps you can run 10:1 or higher with a good tune), a good cam, head work, and headers should make the mid 300s easily.
What transmission do you have? Does it have overdrive? Is it P R N (D) D 2 1 or P R N D 2 1?
MrSony
6,831
6,741
Des Moines, Iowa
And do stick to one thread, please.
RegalBegal
705
747
Goldsboro, NC
Welcome. Mr.Sony beat me to it. :ROFLMAO:
Oct 14, 2008
8,825
7,779
Melville,Saskatchewan
An Olds 403 is another bolt in place option that everything fits but they are the light weight windowed blocks. There gigantic 4.351 bore makes up for it. Slightly milled early heads with 2"/1.625" or 2.07"/1.625" valves added with the bowls opened up if the stock pistons can be reused or Procomp/Edelbrock/BBO or stock reworked heads with KB 6cc hyper or Arias 3cc forged pistons with enough cam to make the power you want and run on pump gas. Add header's and dual exhaust to your 307, they will transfer over to either the Olds 350 or 403.
MrSony
6,831
6,741
Des Moines, Iowa
Sorry messed up because I couldn't figure out. How to make a post lol but I don't have overdrive
Olds 350/BOP Th350 would literally drop right in.
565bbchevy
9,614
12,683
Michigan
86' Regal with a 307 should have the 200R4 in there if it's original
