78mali350 said:wow that looks great! what is the paint that you are using on your undercarriage? and what is the process? any prep work to those pieces?
dogshit said:Great job! Can't wait to see the buildup on your 350. Did you get the rear sway bar with the 8.5 and do you have the thicker front sway bar? Also never seen the Olds wheels in 15x6 before whats the scoop on that?
350_85cutty said:Super nice car you have there! like everything you've done to it so far. and I like how you kept everything original on the outside and that your keeping it all Olds, is it a brougham? how did you come across it?
Larryg said:Wow! Lookin good! I love the subtle, factory look.
Anyways, I'd like a 2 inch drop like yours will be getting and the 8.5 as well. Are drop spindles the best way to go as opposed to the simple spring change? Does this mean you'll have most of your suspension working correctly as opposed to the spring guys LOSING 2" of travel? What spindles are you going to use along with springs? What are your plans for motivation? Stock?
