they have a switch to go solid, but ill be damned if i ever use it i think they look good yeah i wish it was side to side might some day see if i can get one of the techy guys at work to reprogram
got the seats put in the car it really stands out in the pictures but it person its not so different, but it def reminds me i need a new dash carpet and all the trim and door panels inside.
the gas tank itself is great fuel system is great, downsides are its not baffled, and its not vented enough it takes f-ing forever to finish filling it once you get just above 3/4 of a tank, its actually worse than the spectra premium tank i had in there before. i don't actually think anyone makes a tank as good as the factory one, i never had a issue refilling mine but i replaced everything when i did the fuel lines and i kinda wish i hadn't but i would have had to anyways for the fuel injection because that fi-tech intank pump i originally was going to use required you to mod the stock tank and no way in hell im cutting and grinding on a tank thats had fuel in it.Awesome build.
What is your opinion/review of the aeromotive gas tank setup? I've been eyeballing that for a couple years now.
its around 13.6 most timesWhat’s your efi a/f ratios set at when at idle
