I would pull the return line at the fuel rail to verify that you do indeed have fuel in the rail.
Yep! Or change the coil. When I was running TPI the 2 plug external coil took a poop on me and did the same thing! It would crank, had fuel, etc but would not fire! I swapped back to a blaster 2 coil I had handy and voila!!!Change the distributor just for giggles.
Did that cruise control bracket and servo come from the Monte SS? I put a 4.3 in a Bonneville, and need to remote mount the servo in a similar manner.
Awesome! I have the Bonneville servo, but that V6 gives me no room to mount the servo at the back of the manifold like the old engine had.It came from the donor car I parted out and used for my TPI setup, a 87' Trans Am. I've seen a couple different cruise setups on TPI cars so not sure what other years might have the same but it seemed to fit and work pretty well for me. The servo itself looks similar to the same one on Monte's and maybe other GM's from that era but I haven't compared them side by side.
